fan oven grill element help
Home Forums Public Support Forums Spare Parts Help fan oven grill element help
  • #39587
    spanky
    the element on my fan oven has gone, the outer element still works to heat the oven its just the grilling part that doesn’t. as this oven was in our property when i moved in here i do not know what make or model it is…..
    i have tried to pull it out of the unit but there’s no visible stickers or information.i do have a picture of the oven and the old element (which does look like the teb03) if anyone could help me? thanks
    [/img]
    #262893
    Re: fan oven grill element help
    Looks like an Arrow to me… It was a Teba badge-job for one of the DIY outlets.
    The TEB03 HERE will be the one you want.
    Power off if you intend to fit this yourself.
    spanky
    are these fairly easy to fit? do i have to take the back off? i have had the oven out but the electric cable is too short so ill maybe have to get hubby to disconnect it from the oven so it can be moved further. thanks again!
