fan oven heating – SI-9TF-GRA
Home Forums Public Support Forums Help And Support Cooker And Oven Forum fan oven heating – SI-9TF-GRA
  • #102266
    vcsggl
    Main oven fan element not heating, replaced with new element from you. Not heating. Checked all connections, all sound, no voltage on live side of element. Checked output on control switch – 9 position switch- no voltage output on connection to fan element. All other switch positions working perfectly. Do I need a new switch or am I missing something ?
    #488154
    vcsggl
    vcsggl wrote:Main oven fan element not heating, replaced with new element from you. Not heating. Checked all connections, all sound, no voltage on live side of element. Checked output on control switch – 9 position switch- no voltage output on connection to fan element. All other switch positions working perfectly. Do I need a new switch or am I missing something ?
    Sorry – Britannia 90, twin oven range
    #488155
    well if you have a look at the contact controlling it you may see its burnt out
    its is likely the switch has blown but i could not say for certain without testing it
    vcsggl
    Thanks Dave
    I.assume I can only view the contact by dismantling the switch and in any event the switch is not designed to be repairable. The price seems very reasonable for once!
    New switch seems to be the next step
