Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Fan Oven not working belling forum 317AN cooker
- This topic has 6 replies, 3 voices, and was last updated 21 years ago by
admin.
March 15, 2005 at 11:05 pm #8499
KeymasterThe main oven is not warming up. The fan at the back of the oven is working, and the light comes on, but no heat. Any suggestions. cooker only about 2/3 years old. Not great at DIY, but don’t want to fork out for someone to repair if it is an easy job. Thanks
March 15, 2005 at 11:39 pm #128951Dave_Conway
ParticipantRe: Fan Oven not working belling forum 317AN cooker
It’s almost certainly the fan element that will have failed which is behind the rear panel inside oven.
The element is around £40.
If you’re going to have a go, make sure it’s disconnected from the supply first :zap:
It’s not an expensive repair though generally so if you’re not confident in tackling it please don’t, check for an engineer near you by checking repairs@ and the directories.
March 22, 2005 at 7:07 pm #128952admin
KeymasterRe: Fan Oven not working belling forum 317AN cooker
Thamks for the information Dave. Unfortunately there was no one listed in the @repairs or directories for my area.
If the part is £40.00, how much would you expect the labour to be?
March 22, 2005 at 7:14 pm #128953Penguin45
That’s the impossible question……… Your repairer will certainly bill you for an hours work – the rate itself will vary widely across the country; London prices will be considerably higher than up here in Leeds say.
If there is no UKW repairer in your area, look for DASA, Fair Trades, or Trading Standards logos, or seek a local recommendation. Assuming satisfaction, tell them to sign up to UKW!
Penguin45.March 22, 2005 at 9:02 pm #128954Dave_Conway
I do have a little list here, pop up the first part of your postcode and I”ll check for you 😀
March 28, 2005 at 1:13 pm #128955admin
Postcode CR0
March 28, 2005 at 5:05 pm #128956Dave_Conway
Sellens Service on 01732 521500 should be bale to help 😀
