Faster Drying Option
  • #66444
    I don’t know if this works as I haven’t a machine to test it on here now but…
    Activating heating element 2 TD60.1 (CD601W)
    Heating element 2 can be activated/deactivated by programming the machine.
    • Turn off the machine using the main power switch.
    • Press and hold the Anti-crease button and turn on the main power switch. This opens the menu for activating/deactivating heating element 2.
    • Press the Time save button to activate/deactivate the heating element. When the heating element is deactivated, the lights for Normal dry and Iron dry flash in sync. When the heating element is activated, the lights for Normal dry, Iron dry and temperature flash in sync.
    • Press the Stop button to save and exit the menu for activating/deactivating heating element 2.
    EFS
    Re: Faster Drying Option
    Can it still be run on a 13A plug with both elements powered up?
    Steve.
    #364194
    So far as I know, yes. Need’s checking though first.
