Re: fault code
Hi Bob,
This is the “Size switch error” – the setting doesn’t match what’s in the computers brain. Check that the size switches (2) are pushed through into the console housing. Thed switches can be faulty, as can be the display module.
However, it can be a setting error. Try pushing and holding Start/Power, then Power. Should reset. If it doesn’t Fast or Kiwi should be able to advise further.
Power off if you go inside.
