What a fantastic site. Already gained some useful info off previous postings, but couldn’t find anything relating to my current problem.
Have a GW501-F that is displaying a fault code of 32 (00100000) during the first part of the wash cycle. Fills ok, then begins to agitate for a few minutes, pauses a few times then beeps with fault code 32 displayed.
According to fault Codes 32 Pump circuit error
The display module has detected that pump is on when it is off
Action Check for Moisture in Console Area or Faulty Display Module
Fairly Unusual error this Id still Check Pump OOB Switch
Thanks for your prompt reply. This same fault code came up on 2 different motor controllers. Did find the main stator was loose on it’s mounting. Tightened it up and no more fault codes. So not sure how the pump error came up at the same time?
