fault code EFO AEG 16830
Home Forums Public Support Forums Help And Support Washing Machine Help Forum fault code EFO AEG 16830
  • #76546
    SteveKLX
    My Washer dryer displays the code EFO.I have stripped the machine down and cleaned all hoses, pumps and filter. The code suggests a leak, however there is no evidence of one. The remedy suggested for resetting the error code is to drain the water away from the anti flood device and as a result of doing so, the code will automatically reset. I have also tried pressing and holding the 2 far left buttons and turning the control dial 2 clicks.(it suggested 1 click but info from another forum suggested 2) then a further 9 clicks, back to off, back on, then off. This also did not work.
    Please if any one can assist I would be very very grateful.
    Thank you
    Steve
    #398739
    Re: fault code EFO AEG 16830
    not all EF codes will reset this way
    there is 1 EF4 that need resetting by an engineer who can then check the machine for a fault
    as a user you will get the code EF0 but if you went into the engineering mode you will get EF1, 2 ,3 or 4
    EF4 Water fill pressure too low , no signal from flow meter and solenoid valve open
    This machine counts the water in with a flow meter same as petrol pumps do. if this meter is not working and the timer expects it too it will lock out to prevent flooding
    #398740
    SteveKLX
    Thanks for your time and info on error codes. As much as I hate saying it, Some times you just have to accept defeat. Ive got an engineer calling tomorrow.
    Steve
