Fault code for aeg fridge/freezer
Home Forums General Trade Forum Fault code for aeg fridge/freezer
  • #7947
    Antposh
    got f5 fault on fridge/freezer
    Any idears lads ?
    regards
    Ant
    #126090
    Dave_Conway
    Re: Fault code for aeg fridge/freezer
    Not without the model Ant 🙄
    #126091
    Antposh
    oko arctis 2792-4ga
    928341004
    81033051
    regards
    ANt
    #126092
    Dave_Conway
    Sorry Ant.
    Nothing about fault codes on the TDS disk for this model 🙁
    #126093
    Antposh
    i know i have looked on there i dunno what else to do cause the applaince is working fine just bit iced up! 😕
    #126094
    johnboy
    F5 fault code relates to incorrect resistance value on the fridge evaporator sensor. Corresponding readings are at 0= 32.51k ohm, -10=54.89,-20=95.89,-30=173.9k ohm.Readings are taken from the edge connector at the board in the top panel. Hope this helps ❗
