Fault code for Candy?
  • #43386
    happycack
    Went to mad woman today, clothes comming out hot and had the machine two and a half years. A Candy G014780. Plumbed in to hot water from combi. Changed it over to cold, tested and out the door. She just rang to say the machine stops and the stain removal button and the 90 degree lights flash. Checked through the known error codes but not having any luck. Anyone out there with any ideas although I’m sure the water change over is nothing to do with it. Classic though ‘was alright before you touched it’ Bless her.
    #277061
    Re: Fault code for Candy?
    happycack wrote:A Candy G014780.
    Bless her indeed but that model number don’t compute anyway. Can you double check for us and best give the 8 digit product code beginning 3???????:D
    #277062
    happycack
    ok Martin I’ll pop along tomoz and get back to you.
    #277063
    timdowning
    Check the heater whilst your there.
    #277064
    Flyman
    Count the number of flashes then refer to normal Hoover/Candy fault codes. The model will be a GO147.
    #277065
    happycack
    Thanks all of you. B.T.W. is the clock out on this site or is it my p.c. Looks like I sent this tomorrow on mine??
    #277066
    happycack
    Went back to the ‘madwoman’ re the machine now not working and the light is flashing. Checked on three different lists of Hoover/Candy fault codes which all point to NTC. Explained all of this to her. (One fault code said possibly heater but that checks out) She now insists that it’s my fault as it was o.k. before I tampered with it. All I did yesterday, with the information from her that the clothes were coming out hot, was to put the machine on a rinse program. With that the combi boiler fired up, I opened the soap drawer and felt the water and it was hot. Pulled the machine out, cold fill only, and it was connected to the hot water supply. I changed this over with the cold supply (both valves had blue levers on them.) Quick run test on rinse and now obviously cold filling. Charged her £30.00, gave her a receipt and left.
    Point is if I thought I was 1 {e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} to blame then I would gladly reimburse her so I didn’t. Now all sorts of cr@p is hitting the fan. What do you think I should?
    #277067
    happycack wrote:Went back to the ‘madwoman’ re the machine now not working and the light is flashing
    Hold up just a second!
    “light is flashing”……My question: what led’s are flashing? Usually two led’s flash together and counting the flashes (repeats every 15 seconds in fact) gives the vital error code?
    So, tell us, how many flashes does your mad woman’s machine show? 😀
    An NTC fault should show 5 flashes by the way. 😉
    #277068
    A thought occurred to me. Maybe it’s one of those clever boards which remembers the temperature of previous wash(es) and when it finds a significant difference (as it would with the water coming in cold) throws up a fault. (Hence NTC). I’m sure there’s a way round this but I ain’t sure what it is 😕 .
    Mike.
    #277069
    happycack
    sorry for the delay, just got back from Malta (don’t ask) Yes the machine does flash 5 times hence the NTC error code. Interesting about the last temperature comparrison, don’t know how you get by that. Mad woman on answerphone wanting to know what I’m doing about breaking her machine, I said I’d get back to her.
    #277070
    helo_75
    tell her get lost
    its another fault , simple as
    if it was ok before you went, why did she call you?
    shes wrong in any event, is it worth all the hassle for £30
    #277071
    Go back,(when you’ve got nothing better to do) change the hose back to hot fill only. See if machine then works again. If so, explain to mad woman about how pcb is too intelligent and if she wants the washing to finish cool, she”ll have to have a new board. If still getting five flashes, change ntc and charge for second fault. (Best put it all in writing.)
    Mike
    #277072
    happycack
    One of those ‘can’t please all the people’ situations I suppose. I’ll just give her her money back and tell her there’s nothing more I can do for her. Not worth the blood pressure.
    Thanks you guys.
