fault codes
  • #64543
    clockworkone
    powerpoint idw12(seems to be an irish brand of rubbish )customer has one that wont progress and is showing e3.are these kenwood or haier copies.anyone got any idea on the fault codes.think may be temp or heater related.paul
    #357341
    Seamy
    Re: fault codes
    E3 is a drain fault, they’re distributed by
    Shomar Ltd
    Unit 9 Western Industrial Estate
    Dublin 12
    Ireland
    T: 01 450 9150
    Fault codes are here ….
    http://www.shomar.ie/PP1000WM_IB.pdf
    #357342
    clockworkone
    Re: fault codes
    thanks seamy,should have said this one is an int dish washer.have spoken to cust since and he says it finishes program but no heat.paul
    #357343
    Seamy
    Re: fault codes
    Likely its a Belling type d’washer, if so its a problem that can be cured by tweeking the pressure switch slightly to take in slightly more water. Level switch gets deactivated & heater drops out due to low level filling.
    #357344
    dave-m
    Re: fault codes
    The heaters on these go all the time, it’s a banana shaped heater one on the inside of the machine, a quick change with the side off. HTR76 is the number in my local Qualtex supplier.
    clockworkone
    Re: fault codes
    thank you seamy and dave. i see quinns quoting haier part nos for these machines.paul
