I have a Hotpoint CTD40P Condensor Tumble Dryer that has stopped
working, it will run for a while and the element gets quite hot for a few minutes judging by the temperature of the casing. It then cools down coinciding with the following lights flashing with the drum continuing to turn:
Time Delay (1), High heat (3) and Alarm (4). The On/Off light also flashes.
I have had the back off and checked the thermostats, heating elements ect. and also ensured there are no blockages.
I have seen on this site that when lights 1,2 and 4 flash there is a problem with the pump, I would appreciate if anyone could tell me what fault lights 1,3 and 4 indicate.
Any help would be greatly appreciated.
Terry
