Hi I hope someone can give me some advice, my 2 year old Beko ca7015ffs1 fridge freezer has started to freeze everything in the fridge!
I have tried turning the setting down and has made no difference, the freezer also seems to be a lot colder than it should be, I also have a ice build up on back of fridge.
The fan in the freezer also seems to be running all the time.
Any advice on what could be wrong? or any tips?
Thanks in advance.
I am a gas engineer by trade so do have equipment to check ntcs etc
First and foremost, this appliance may be one of the Beko products that was recalled.
CALL BEKO on 0800 009 4837 with the ser’ umber, model number etc to check.
Fault on fridge could be that the t’stat is faulty (always on) or its low on gas for instance and not going cold enough to knock off the t’stat in fridge so running continuously and build up of frost, ice etc. Best to get a refrigeration guy to have a look.
Thanks for the info, my FF is not one of the ones that were recalled, I checked when it was in the news
Low on gas? is it normal for a 2 year old fridge to go low on gas? its just my old fridge/freezer worked for over 12 years! or is it a case of they dont make them like they used to!
Like I said both fridge and freezer are very very cold!
