Fault with electric cooker tripping out
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Fault with electric cooker tripping out
  • #63541
    chrispike
    Our electric cooker keeps tripping out, I’ve tried the electric switches for loose connections and also tried swapping round the RCD to see if it was faulty. Could anyone give me some advice? Cheers!
    #354075
    Re: Fault with electric cooker tripping out
    Do you have access to a megger and know how to use one?
    If yes then you need to isolate from the mains and check all components and wiring for insulation faults.
    If not then you really should get it looked at by someone who has the requisite test equipment etc.
    PS. A make and model would also help. 😉
