I am having some issues with a Hygena Select 8224/1.
Recently the upper and lower sprayers stopped spinning.
I removed the sprayers and cleaned them.
I removed the filter and cleaned it.
I took off the removable filters at the base of the machines and found the reservoir was full of water.
I found there were two pipes that feed into the reservoir. The pipe on the left was blocked., I unblocked as best I could, but when I tested it the sprayers still did not spin and the reservoir does not drain.
My questions;
What are the two pipes in the reservoir used for? I think one allows the water in and the other drains it out, but I’m not sure! As I mentioned, the pipe on the left was blocked, could it still be the cause of problem?
If that is the fault, how do I access it to clean it properly?
There is a cap inside the dishwasher on the left side, it has a 1,2 and 3 marked on it. What is this for?
