Faulty Hygena AHY 8122
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Faulty Hygena AHY 8122
  • #16200
    crisiebabe
    My Hygena AHY 8122 is faulty again. The programer dial doesn’t turn, it sounds like the pump is running but it doen’t fill with water and it’s leaking out of the bottom of the machine.
    My previous fault last year after some good advice from this site was a faulty door switch. Many Thanks
    Hope somebody can help.
    Chris
    #168775
    Dave_Conway
    Re: Faulty Hygena AHY 8122
    It sounds like a leak in to the base causing the anti-flood device to activate, try leaning the dishwasher (with towels handy ;)) and see if any water runs out.
    It may work once the base is cleared of water but the underlying fault will need to be rectified.
    Power of please if you go any further :zap: or check the repairs@ link below if you need an engineer 🙂
    #168776
    crisiebabe
    Thanks for the resonse.
    The water did seem to come out when I tipped the machine. What faults are most likely. I don’t mind having ago myself, as I do have an engineering back ground.
    Chris
