faulty indesit di620 lights 1 and 4 on
Home Forums Public Support Forums Help And Support Dishwasher Help Forum faulty indesit di620 lights 1 and 4 on
  • #54372
    apl
    hi can anyone help me please i have a indesit di620 and the neon lights 1 and 4 are on but the dishwasher is not doing anything had a engineer out who said there are two pcbs and its the one under the machine that is faulty.I am a boiler diagnostic engineer so i had a look before calling anyone out and could only see one pcb behind the door with a wiring loom coming off it to under the machine, the engineer is saying the pcb will cost a fortune and he will have to take the machine away to test for over a week of testing in his shop could anyone help me please as i got the impression the engineer didnt want to repair it thanks. 😀
    #319379
    Re: faulty indesit di620 lights 1 and 4 on
    In some ways you can’t blame him, they are one of the biggest piles of poo on the market TBH. 😥
    As you have found it does only have one PCB in the door, the later machines do have two.
    Lights 1 + 4 are supposed to signify a software error, the electronics are woeful on these machines. Some of the PCB’s are quite cheap but the ones for yours are over £60 ex vat.
    There are two different ones and the full serial number is required to identify.
    Firstly though you should run your megger over the internals, the heater in particular can throw up spurious error messages if it is down to earth, although yours has the better ‘in tub’ heater as opposed to the tube type which is less reliable.
    #319380
    apl
    How do you test the heater and what readings would i be looking for thanks.
    #319381
    Erm, I would have thought a boiler diagnostic engineer would know how to carry out an insulation test. You want the best possible reading so infinity or >999 is as good as it gets. 😉
    The heater terminals can be accessed from underneath, you will have to remove the base to get at it. As I have mentioned though, this heater is far more reliable than the tube type.
    Look out for signs of leaks on the baseplate and around the motor as well.
    #319382
    apl
    sorry misunderstood your amswer had a long night mum rushed into hospital thanks for your reply
    #319383
    No problem, hope she is recovering.
