Faulty lid switch F & P Smartdrive gw501
Home Forums Public Support Forums International Forums Australasian Appliance Forum Faulty lid switch F & P Smartdrive gw501
  • #29892
    keith.r.smith
    I have what seems to be a faulty lid switch. In diag mode leaning on the RHS of lid causes bit 32 to go on and off.
    Where is the switch?? I can’t seem to work out how it works or see any wiring around that relates to it
    #225124
    Re: Faulty lid switch F & P Smartdrive gw501
    501 lid switch is situated under the top deck. There is a magnet moulded into the lid, closing the lid should activate the switch. Remove the top deck (couple of screws at the back of the control panel) for access. Check for wet, corroded wiring and connectors; switch itself may be faulty.
    Lid switch and harness is p/no 426457 if required.
    Pull the plug first………
    bigsmokepiker
    501 Lid Switch Differs from Later Models
    The Lid Switch is integrated into the display model
    If You remove Lid you will see the a Little red Striker That Activates Lid Switch,Check to see if this little striker has not come out or is worn
    Part # 426457 will not fit this Washer
    #225126
    Oops – thanks, BSP.
    keith.r.smith
    Thanks for the help
    Problem resolved
    Keith
