Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Faulty motor, worth fixing?
- This topic has 6 replies, 5 voices, and was last updated 20 years, 3 months ago by
ZanussiFL1085.
December 13, 2005 at 12:01 pm #14020
ZanussiFL1085
ParticipantI have a Zanussi FL1085 washing machine which is no longer spinning the drum, although it fills and drains. The drum very occasionally spins, but makes a nasty noise. When the cover is off the top you can see blue Arching coming from inside.
I’m guessing the motor is somehow faulty, I’d of thought if it had thrown a wind etc it would no longer work. Could the brushes just be worn and intermittantly making contact or is it a complete new motor that is needed? How long would the job take, is it worth it? Any idea where is the cheapist place to get the parts?
Thanks for any help, much appreciated.December 13, 2005 at 12:49 pm #157570Dave_Conway
ParticipantRe: Faulty motor, worth fixing?
It sounds like the brushes have worn, only a physical examination will tell for sure though.
The brushes will vary according to the make of motor also as Zanussi use 2 or 3 types generally.
Power off when investigating please :zap:
December 13, 2005 at 1:46 pm #157571ZanussiFL1085
Dave_Conway wrote:It sounds like the brushes have worn, only a physical examination will tell for sure though.
That’s great thanks. Is there an easy way to access the brushes as the only way I can see to get to the motor at the back of the drum is to remove the whole case, there is no access plate?
By the way, out of intrest, there seems to be another motor (not the pump) at the bottom of the machine, under the drum, what is the purpose of this?
As you can tell I’m a bit of a novice at domestic appliances, but don’t worry the power is off as soon as it’s open.
Thanks for the help.December 13, 2005 at 2:10 pm #157572Martin
Access the motor via removing the rear half panel, loads of screws, plenty of swearing!
December 13, 2005 at 4:05 pm #157573farmboy
ZanussiFL1085 wrote:
By the way, out of intrest, there seems to be another motor (not the pump) at the bottom of the machine, under the drum, what is the purpose of this?There is only 1 motor and that is the one at the bottom 😉
December 13, 2005 at 4:56 pm #157574jeremy
i would advise you find someone to look at it that knows what they are doing as there is only one motor in there !
try repairs@ 🙂
December 13, 2005 at 6:14 pm #157575ZanussiFL1085
jeremy wrote:i would advise you find someone to look at it that knows what they are doing as there is only one motor in there !
try repairs@ 🙂
I just had a quick look at the machine late last night. I could see the motor at the bottom, but assumed that there was a motor on the back of the drum driving it, not the one at the bottom. But I could’nt tell without removing the machines case, now I know the motor at the bottom drives the drum via a belt I assume. I’ll have a better look when I have some more time and take the case off it, then inspect the motor brushes.
Thanks to everyone who’s offered advise. -
