Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Faulty New World Series Two Built in Cooker
- This topic has 6 replies, 2 voices, and was last updated 20 years, 4 months ago by
MartinH.
November 21, 2005 at 8:20 pm #13476
MartinH
ParticipantMy cooker has ceased to function properly this evening.
The cooker ignites as usual but the flame stays at the lowest (initial) level. Turning up the dial sees no increase in power!
I used it to cook this evening early on and it worked fine. I went to put it back on again later and it no longer works properly!
The hob works fine so no probs with the gas feed in general.
The cooker has also been subject to continually trying to ignite even when lit since we have lived here.
Any clues would be much appreciated.
MartinH.
November 21, 2005 at 8:33 pm #155084Dave_Conway
ParticipantRe: Faulty New World Series Two Built in Cooker
The FSD has failed which will require a Corgi registered engineer to replace for you. Not an overly costly repair 🙂
Check Repairs@ for one.
If that throws a blank, pop up your postcode and I’ll see if I can recommend anyone for you.
November 21, 2005 at 10:50 pm #155085MartinH
Cheers Dave,
I’ll book in an engineer ASAP.
Whats an FSD by the way? Ive since noticed that if I leave the dial at gas Mark 5 the power of the flame fluctuates. Does that help further?
Thanks again,
MartinH.
November 21, 2005 at 11:08 pm #155086Dave_Conway
Flame supervision device or sometimes called an FFD (flame failure device), an extremely important safety component on all gas appliances.
Central heating boilers use a thermocouple to do the same job as do some gas fires and a few cookers.
Basically it stops or decreases the gas flow to a safe level should the flame go out for any reason.
The engineer who attends will check the thermostat while he/she is there ref the fluctuation on GM5 😀
December 5, 2005 at 7:10 pm #155087MartinH
Evening Dave (Or any other Mods).
I put a repair request in on he 23rd Nov (ish) and although I have had an email outlining the suggested engineering co. I have heard nothing from them. 🙁
Do you have any other suggestions locally?
(Post code is LU7).Thanks in advance.
December 5, 2005 at 9:09 pm #155088Dave_Conway
Most odd, it went to FFR Services who play a staring role in Repairs@ 😀
The only thing I can imagine is the email went astray, did you get a confirmation email with the number on for FFR ?
I’ll email them anyway and cc you in in a few minutes 🙂
December 5, 2005 at 10:06 pm #155089MartinH
Thanks for chasing that up Dave!
Original job no. was 00930.
Speedy reply is much appreciated. 😀
