Faulty Samsung SR-L3626B fridge-freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Faulty Samsung SR-L3626B fridge-freezer
  • #50724
    We have had our Samsung SR-L3626B fridge for about about 6 years. It has recently developed a strange fault whereby when it is powered on, the fridge and freezer will cool and compressor & fan will run for a few hours. After this, the fridge-freezer remains in standby but the compressor does not start again. So eventually the fridge and freezer compartments start to get warm.
    Both the PSU and control PCBs have been replaced with new ones.
    It just seems like a really odd fault which can only be rectified temporarily by powering the fridge-freezer off and then on again.
    I have tried invoking the test mode as per the service manual however, the display does not indicate any fault codes?
    I have also measured the resistance of the thermistor in the fridge and it is within the range that the service manual specifies?
    Any help would be gratefully appreciated.
    Thank you.
    #305745
    spimps
    Re: Faulty Samsung SR-L3626B fridge-freezer
    Check the defrost heater,usual culprit.
