Faulty Smeg Dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Faulty Smeg Dishwasher
Viewing 2 posts - 16 through 17 (of 17 total)
  • #120334
    clivejameson
    Re: Faulty Smeg Dishwasher
    There is a right angle bend in that tube which you need to clean around…if that doesn’t do it then it’s engineer time to clean or replace the metering tank as required i’m afraid.
    #120335
    smeg_user
    clivejameson wrote:9 times out of 10 its a food blockage in the transfer pipe between the metering tank and the sump. You can do a DIY which will almost certainly clear it….lift out the filter in the base and at about the one o’clock position in the sump
    Clive
    | have a DWD61SS – This worked for me but only after I had changed the timer. When it first started playing up, it appearded as if the timer wasn’t advancing. After changing worked OK until dishwasher was refitted.
    Fingers crossed, following the cleanout it has worked faultlessly for three washes and has now been refitted.
    Go for the easiest (and cheapest) options first !!
