hi,looking at a zanussi washer fs1155,when you try to start a program,the wash light comes on,door interlock clicks 3 times,then end lights up,all in a matter of secounds,checked over,tryed a door interlock,im guessing the main power board,any ideas would be welcome,cheers
It is important that you check all the components (i.e Motor, heater, pump) for continuity otherwise an error like you are experiencing will result. Have you run the ‘diagnostics’ programme? 😉
