F&B smartdrive trying to fill then error
Home Forums Public Support Forums International Forums Australasian Appliance Forum F&B smartdrive trying to fill then error
  • #10882
    In diag I get the following
    from 1111 to 0000 those being order Hold-Slow-Med-Fast
    01000111
    00101101
    00110100
    00101011 (last one is flashing slowly)
    11111111
    00000100
    10001111
    00000100
    10001111
    00010100
    00000000
    00000000
    00101011
    00000000
    Hope this enough info to work out what the problem and someone is willing.
    please email me on ukwhitegoods at dylanjay dot com
    #143079
    Re: F&B smartdrive trying to fill then error
    Which one relates to hold+slow lights? 😕
    #143080
    Looks like that code is 0
    HSMF – 01000111
    0SMF – 00101101
    H0MF – 00110100
    00MF – 00101011 (last one is flashing slowly)
    HS0F – 11111111
    0S0F – 00000100
    H00F – 10001111
    0SM0 – 00000100
    H0M0 – 10001111
    00M0 – 00010100
    HS00 – 00000000
    0H00 – 00000000
    H000 – 00101011
    0000 – 00000000
    #143081
    What is the problem?
    #143082
    When you start it it will attempt to fill up. It will start/stop/start… filling for about 1min and then eventually beep and give up with some lights lit up.
    #143083
    It sounds like the OOB (out of balance) switch is faulty. Remove the top console and the motor controller, the switch and bracket is on the rh side. There should be signs of corrosion around the terminals. P/n for new 420313. Also check the bowl is springing back on all four corners when you press it down. Hope this helps. 😉
    #143084
    are there some instructions on how to remove these someone can send me? or is it straightforward?
    #143085
    Once you have a look, you will see it is straight forward. But if you dont feel confident, get a professional.
    #143086
    djay
    I opened it up and had a look. I think the switch you mean is the one located beneath the control panel that is a grey box with a white stick sticking down next to the drum right? I had a look at it but I couldn’t see any terminals. Its just plastic.
    Are you sure this sounds like a balance switch problem? It starts and stops when filling at the start of the cycle? It wouldn’t be rotating at this time would it?
    #143087
    djay
    Just subscribing to this thread
    #143088
    You need to remove the panel that the buttons are on, then the control module under that, and you will see the switch assy. It is what you are looking at but on the other side of the plastic. 😉
    #143089
    djay
    Ok. It’s corroded just as you said. So if I replace this part, how sure now are you that this will fix my problem? 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}?
    #143090
    pookky
    You can confirm the fault is in the switch by connecting the 2 wires to the switch together as the switch is normally closed.
    Don’t leave it that way or you could have bigger problems if the machine gets out of balance!
    Also unplug the machine before you touch any wiring!
    #143091
    Browny
    I have an MW059AU (Pride smartdrive) and it keeps turning the solenoid on and off whilst it is trying to fill, sounds like same problem. When I press the wash temp down and power button together I get no fault LEDs. I tried bridging out the OOB and door switches but had same result. I thought it might be a water level problem, I can blow air through the level indicator tube and suck water back through. I tried pushing down the plunger on the level transducer whilst trying to fill the machine, this causes the solenoid to turn off but the machine does not proceed to the next step. Would you recommend replacing the motor control board? My local distributor has one in stock but as you know it is an expensive part. The machine is only 3 years old. I look forward to any advice anyone could give me. Thank you.
    #143092
    Do you get any fault indication at all? 😕
