Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › F&B smartdrive trying to fill then error
- This topic has 15 replies, 5 voices, and was last updated 20 years, 8 months ago by
admin.
July 25, 2005 at 3:46 am #10882
KeymasterIn diag I get the following
from 1111 to 0000 those being order Hold-Slow-Med-Fast01000111
00101101
00110100
00101011 (last one is flashing slowly)
11111111
00000100
10001111
00000100
10001111
00010100
00000000
00000000
00101011
00000000Hope this enough info to work out what the problem and someone is willing.
please email me on ukwhitegoods at dylanjay dot comJuly 25, 2005 at 11:18 am #143079KiwiwantsworkinCanada
ParticipantRe: F&B smartdrive trying to fill then error
Which one relates to hold+slow lights? 😕
July 26, 2005 at 12:42 am #143080admin
KeymasterRe: F&B smartdrive trying to fill then error
Looks like that code is 0
HSMF – 01000111
0SMF – 00101101
H0MF – 00110100
00MF – 00101011 (last one is flashing slowly)
HS0F – 11111111
0S0F – 00000100
H00F – 10001111
0SM0 – 00000100
H0M0 – 10001111
00M0 – 00010100
HS00 – 00000000
0H00 – 00000000
H000 – 00101011
0000 – 00000000July 26, 2005 at 5:52 am #143081KiwiwantsworkinCanada
What is the problem?
July 26, 2005 at 6:02 am #143082admin
When you start it it will attempt to fill up. It will start/stop/start… filling for about 1min and then eventually beep and give up with some lights lit up.
July 26, 2005 at 7:22 pm #143083KiwiwantsworkinCanada
It sounds like the OOB (out of balance) switch is faulty. Remove the top console and the motor controller, the switch and bracket is on the rh side. There should be signs of corrosion around the terminals. P/n for new 420313. Also check the bowl is springing back on all four corners when you press it down. Hope this helps. 😉
July 27, 2005 at 9:31 am #143084admin
are there some instructions on how to remove these someone can send me? or is it straightforward?
July 27, 2005 at 7:00 pm #143085KiwiwantsworkinCanada
Once you have a look, you will see it is straight forward. But if you dont feel confident, get a professional.
August 2, 2005 at 8:20 am #143086djay
I opened it up and had a look. I think the switch you mean is the one located beneath the control panel that is a grey box with a white stick sticking down next to the drum right? I had a look at it but I couldn’t see any terminals. Its just plastic.
Are you sure this sounds like a balance switch problem? It starts and stops when filling at the start of the cycle? It wouldn’t be rotating at this time would it?
August 2, 2005 at 8:22 am #143087djay
Just subscribing to this thread
August 2, 2005 at 8:32 am #143088KiwiwantsworkinCanada
You need to remove the panel that the buttons are on, then the control module under that, and you will see the switch assy. It is what you are looking at but on the other side of the plastic. 😉
August 2, 2005 at 8:45 am #143089djay
Ok. It’s corroded just as you said. So if I replace this part, how sure now are you that this will fix my problem? 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}?
August 7, 2005 at 10:24 am #143090pookky
You can confirm the fault is in the switch by connecting the 2 wires to the switch together as the switch is normally closed.
Don’t leave it that way or you could have bigger problems if the machine gets out of balance!
Also unplug the machine before you touch any wiring!
November 14, 2005 at 10:49 pm #143091Browny
I have an MW059AU (Pride smartdrive) and it keeps turning the solenoid on and off whilst it is trying to fill, sounds like same problem. When I press the wash temp down and power button together I get no fault LEDs. I tried bridging out the OOB and door switches but had same result. I thought it might be a water level problem, I can blow air through the level indicator tube and suck water back through. I tried pushing down the plunger on the level transducer whilst trying to fill the machine, this causes the solenoid to turn off but the machine does not proceed to the next step. Would you recommend replacing the motor control board? My local distributor has one in stock but as you know it is an expensive part. The machine is only 3 years old. I look forward to any advice anyone could give me. Thank you.
November 24, 2005 at 7:36 am #143092KiwiwantsworkinCanada
Do you get any fault indication at all? 😕
