fdl570
  • #68406
    DDSDDS
    have the above machine
    first call no drain discovered drain pump faulty so replaced and tested all fine
    weeks later call back no heat found heater dead so ordered fitted and tried again
    after it had been on the normal cycle for almost 2 hours the machine stops and the 2 lights on the left flash and start pause flashes but the wash dry and end lights do not flash i have checked known error codes but this does not appear to be listed
    any ideas folks
    thanks in advance
    #370956
    washtronics
    Re: fdl570
    wash motor fault, if you changed the heater the chances are that the wash motor caused the heater to go in the first place, these are poor quality indesit dishwashers and common for both parts to fail just out of guarantee.
    #370957
    DDSDDS
    Re: fdl570
    thanks for the reply
    since posting i have tried it again on the quick wash and it went through but on the normal wash it seems to develop the fault
    only fitted ti 3 week ago
    #370958
    DDSDDS
    Re: fdl570
    tried it again on other cycles and it goes through ok wash motor runs fine
    any ideas?
