Done a few of these now but dont like using Jubilee clips as they are never perfectly round and are prone to leaks.
Can anyone suggest a better idea.
Thanks Graham
You can get the blitz clips that are already fit to them,use a pair of pincers to tighten them up.
Personally I have never had a problem with the jubilee clips we use quite a narrow flexible one and it pulls in no problem.
have changed hundereds of these and I use a terminal screwdriver to slacken the clip off by inserting driver in raised part of clip and twisting slightly to releave tension on clip . remove heater , insert new heater and retighten clip with either sidecuts or endcut pliers.
if you mean the tube heaters I get skinny jubilee clips from Perrys, our local vauxhall dealership. They’ve never let me down (the clips) and they don’t cost a fortune either.
Try http://www.stagonset.co.uk jubilees in stainless 7m wide very adaptable and good quality and not the heavy gauge type so form well around the heater tube,used on commercial dishwashers etc.
just found what i think is the propper tool for these clips on http://www.justoffbase.co.uk part no vs1664 £8.58 inc vat im going to order a pair to try
