Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › fdw20 Hotpoint Dishwasher
- This topic has 8 replies, 5 voices, and was last updated 15 years, 11 months ago by
OLLIE2806.
April 30, 2010 at 4:00 pm #54314
OLLIE2806
ParticipantHi guys,
I have a problem with the above dishwasher that it does nothing just the wash / 2nd led come on a couple of seconds after you start it. I’ve changed the inlet valve, the heater is not open circuit, The insulation resistance of the machine is fine, Will this means its the pcb?
Thanks,
Ollie.April 30, 2010 at 8:00 pm #319179OLLIE2806
ParticipantRe: fdw20 Hotpoint Dishwasher
Anyone?
May 3, 2010 at 6:19 pm #319180OLLIE2806
Does anyone have any ideas with this?
May 3, 2010 at 6:31 pm #319181timdowning
Light 2 on its own isn’t an error as far as I can recall?
You say it does nothing just the wash??
If the machine fills, circulates and drains ok. And you have checked the heater then I would go for the board. Make sure you order the board using the serial number as there are normally two types.
Tim.
May 3, 2010 at 6:38 pm #319182gandh1
If the machine fills, circulates and drains ok. And you have checked the heater then I would go for the board. Make sure you order the board using the serial number as there are normally two types.might be wrong but i read it as the 2nd led / wash led comes on but other than that the d/w is dead
May 3, 2010 at 6:52 pm #319183OLLIE2806
It doesnt fill – doesnt do anything just the 2nd light comes on
May 3, 2010 at 8:40 pm #319184iadom
ModeratorRe: fdw20 Hotpoint Dishwasher
Do you mean the light is on steady.
Have you tried holding the start button in for five or six seconds to clear.
If that doesn’t do the trick then it does look as though the PCB is borked.
May 3, 2010 at 8:55 pm #319185OLLIE2806
Yes the light is just steady, I’ve tried resetting it by holing the button and also turning the dial to reset but all that happens then is that light goes out, so you re select a prog and that wash light just comes back on again.
(Also the salt light stays on but it does look low on salt)May 4, 2010 at 12:37 am #319186leavemetogetonwithit
As the much-missed* John Major once said, back to basics:
Is there 240v across the inlet valve?
If yes, then valve is faulty or H2O supply pressure / blockage in supply. Could try filling dw using a saucepan to required level and see what happens.
If no 240v at valve, trace wiring back to board / request circuit diagram.
Mike.
*Nostalgia’s nothing like it used to be. -
