FDW60
  • #57591
    maltheviking
    Got a motor error fault coming up on one of these (leds 3+5) Motor tests out ok.
    Machine fills then goes straight into pump out, then error 3+5
    Anyone know if there is any other fault that can cause this before I order a new module?
    Mal
    #331688
    loopey
    Re: FDW60
    had one of these yesterday with the same fault code , its not the pcb ,
    it was water in the pressure switch pipe the one on the right that controls
    the heater . had me baffled for a couple of hours lol after new pcb fitted ..
    hth phil
    #331689
    maltheviking
    Re: FDW60
    loopey wrote:had one of these yesterday with the same fault code , its not the pcb ,
    hth philThanks for that Phil but I had already checked the pressure sw and pipe along with everything else. 😕
    #331690
    Re: FDW60
    Could be blocked filters.
    3+5 = Mesh plate, filter or microfilter, pressure
    sensor, pressure switch, circulation motor.
