went to this one this morn.fault reported was no heat.checked heater and no prob there.changed module(c00143209) m/c ser no is 412141736.went through procedure to take out of test but all m/c does now is pump out and give out vibration sound like inlet valve getting no water(valve tests out fine 4000ohms)inlet filter clean. do not think i have been able to get it out of test mode because salt refill and rinse aid flashing on start up.no codes showing.paul
