fdw60 d/washer
  • #55169
    dopper
    fdw60 d/washer code 4 and 6 = heater teased hear which is ok put a newpcb on customer said it worked once then same code, got it in work shop worked on quick wash then on eco code same code came on as it was on drying part. anyone advise
    dop
    #322147
    dopper
    Re: fdw60 d/washer
    had it on test in shop seems to work once ok then next time 4 and 6 code and so on, whys it working 1 on 1 off?
    dop
    #322148
    A1engineer
    Re: fdw60 d/washer
    make sure ntc is properly attached at soap drawer, it could well be a duff pcb or bad connection, the 100 bit pcbs are really bad for it,
    #322149
    RocketMan
    Re: fdw60 d/washer
    had one a couple of weeks ago. Customer assured me it was heating ok
    when I looked ntc wasn’t fully home, so re-seated it, checked all connections, worked intermittently ok, so replaced pcb. same result, customer tried it for a few days still the same. I eventually fitted a new heater (which incidently I had checked and megga’d ok) 10 days ago and after a week customer sent me text and said it had ran through 10 washes perfectly 😡 😡 😡 … haven’t done the maths but probably took a hit on this one.
    All the time still heating. The only thing I can think is an intermittent heater fault??? I would have thought the heater would fault every time??
    hth
    #322150
    dopper
    Re: fdw60 d/washer
    ive got a heater in stock may try that
