I have a Hotpoint FDW60 we changed the element on it due to no heat it now heats up ok but there is no feed down to the drain pump, tried to PCB still no feed, is the engineer missing something simple?
I think the drain pump is routed through the wash motor on later machines, had one that worked OK until the circulation motor got hot then drain pump would not run.
