Re: fdw60p error lights
Classic and very common fault on these Indesit made appliances. :rolls:
No heat fault, 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time it will be either the heater or the control PCB.
A resistance/continuity test of the heating element after first removing the mains plug would be the first step, if that is OK then its likely to be the PCB.
A few different PCB’s used on these so all of the numbers on the rating plate needed to identify correct part, PCB is around £70+.
