FDW70 HOTPOINT
  • #42232
    S1MON
    Have replaced heater(scaled) and main control pcb.
    You set it to wash on program 2 for 1:12 mins and after approx five minutes the wash time readjusts to 1:50 and takes nearly 2 hours to do a wash. Now I have tested it on other programs and they do not change??
    Any clues?
    #272806
    Re: FDW70 HOTPOINT
    Did you fit a new eeprom, or swap the old one over?
    S1MON
    just fitted the new board with the sensor that clips onto the dispenser
    #272808
    Re: FDW70 HOTPOINT
    If you fitted a C00144658 it seems as though you should have swapped the eeprom from the old board or fitted a new one with the board.
    #272809
    evo1
    Re: FDW70 HOTPOINT
    these figures are NOT times, the processor constantly looks at the variables ie water pressure, temp etc and recalculates as long as it completes with no errors 2 hrs is not out of the ordinary, washing machines are the same, times displayed will vary back and forward throughout the wash cycle and it is not a fault
