fdw80p hotpoint dishwasher.
  • #33417
    bzz67
    got one of these in for repair. fills to level, starts circulating & heating ok.
    after a short time the circ pump stops but the heater stays on, after 30 seconds or so the circ pump starts back up then stops again & so on.
    as the water in the heater has no movement at times it boils.
    power to the the motor is cut, there are no breaks in wires.
    could someone confirm that this is a control board fault.
    a part number would be usefull as there apears to be two possibles.
    serial number is 31712648
    #238556
    Re: fdw80p hotpoint dishwasher.
    PCB always a good bet with these, might be tempted tp see if there’s a safety cut-out in the motor winding though.
    kiddo66
    I have had a few of these motors seize after washing for a while,you would be able to tell as the motor gets a tad hot.
