Feed hose for Hoover condensing dryer VHC 392 T
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Feed hose for Hoover condensing dryer VHC 392 T
  • #70315
    twicknix
    It was rubbing against the drum thus causing it to leak, on Connect website, they do offer replacement but as special order. It’s called flow pipe, the one runs from the bottom to the top into the drawer.
    What’s the alternative part? I’m thinking rubber hose instead of plastic but on the bottom the grommet is rather large so the rubber hose may not fit.
    I did a temporary repair using insulation tape to seal up the graze. So the hose would need replacing sooner rather than later.
    #377783
    The grey corrugated hose is the only option and you’ll need to reposition the pipe away from the drum using cable ties or duck tape.
    #377784
    twicknix
    Thanks Martin, have ordered new hose. It better arrive before I go caravanning which is two weeks time.
