felt bearing beko drcs 68w dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries felt bearing beko drcs 68w dryer
Viewing 15 posts - 1 through 15 (of 15 total)
  • #60510
    funbobby
    anyone changed on of these? it has completly shredded the old one and looks like bit of a pig getting the front off, any tips?
    #342504
    whiskey_six
    Re: felt bearing beko drcs 68w dryer
    BACK OFF, DRUM OUT AND DEAD EASY TO GET TO, JUST DOUBLE SIDED ON ( HOWEVER ). Beko have now changed the design due to this fault, when you change the felt, it will last a week or so then come off again, jams the drum and snaps the belt. This is the major cause of snapped belts and we are doing about 10 full rebuilds under 1st year a week for Beko and they are a ball ache. The design change entails fitting a whole redesigned front duct and bearing assembly and redesigned drum, they are not interchangable. :rolls:
    If you just want the part number for the stick on cloth bearing its 2961080100
    #342505
    funbobby
    thanks for that very interesting, belt not snapped yet but seems a big job to modify all the bits on such a cheap machine!
    #342506
    dave-m
    I just got a call for a snapped belt on a DRCS76W. Its only a few weeks out of warranty, does it need one of these mod kits also? should I go at it or should i get them to chance their arm with beko?
    dm
    #342507
    bigchrisoioi
    if the drum is loose, i do just the belt!!!…however warn customer if belts breaks again, its new drum and front bearing duct……the belts are cheap and i can cover the cost…. if the drum is siezed when u get there, then its the full monty !
    #342508
    dave-m
    I’ll check it out,
    Thanks for that
    DM
    #342509
    loopey
    A little tip that sorted one of these that kept braking up the front felt added some baby powder to front felt , also used chalk powder that was 15 years old from the good old hoover tumble dryer days .
    hth
    phil
    #342510
    boselecta
    I have one of these that I have to replaced the front felt seal. What will putting chalk powder on the seal do?, wonder if I should do this on my one?
    #342511
    cab
    weve had a tech bullitin from Beko
    #342512
    boselecta
    cab wrote:weve had a tech bullitin from Beko
    Ok, what did the tech bulletin say?
    thanks
    #342513
    cab
    [/img]
    #342514
    boselecta
    thanks cab
    #342515
    ELDAR59
    anyone know what the tech bulletin was?
    cheers.
    #342516
    boselecta
    http://imageshack.us/photo/my-images/9/bekotd.jpg/
    #342517
    ELDAR59
    Thanks for that mate.
