Got an few10 machine in everything looks fine visually pcb no blow marks all harness is fine, but it will not hit it’s fast spin it cuts off too early to end cycle any ideas anyone.
Check for loose tacho magnet, sometimes the machine needs to warm up before the magnet starts to slip on the shaft. A bit of loctite and a sharp tap usually does the trick.
