Few12 program module help
  • #56641
    A1_Domestics
    Fitted a board from what I thought was the same model machine and now It doesn’t get any fast spin.
    Motor and pump test ok, so the only option I’m left with is to reprogram the board. We’ve only got the config codes for the wma’s so would appreciate any help on this.
    #328245
    Re: Few12 program module help
    ring tony at emw am sure they can test and reprogramme
    A1_Domestics
    I’ve used EMW plenty of times and they do a great job but I’m sure if it’s not a simple reprogram I will be ordering a new pcb.
    #328247
    Is it a screwed or welded drum?
    #328248
    A1_Domestics
    Screwed. I hope I ain’t though!
    #328249
    Check your inbox. 😉
    A1_Domestics
    fixed!
    Jim, this is for you: http://amiawesome.com/
    #328251
    And the problem was ………..?
    A1_Domestics
    For future reference, the wires on the board going to the pressure switch and the heating element were crossed.
    in the past this had the effect of not releasing the door lock, but on FEW machines causes no fast spin. Luckily, the pcb has not been affected.
    #328253
    😳 8)
