FF72P Baffle
  • #48822
    subs
    This Hotpoint is freezing in the fridge. On testing the baffle i have continuaty through the motor (2 black wires) but none through the 2 white wires. Are the white wires the feed back to the board to tell position of baffle maybe. No fault code when i do test. Not sure if its fridge sensor or baffle. Baffle was actualy closed when i got there but opened when i put it back together so its doing something.
    Any Help Please?
    Subs
    #297837
    spimps
    Re: FF72P Baffle
    Fridge thermistor controls the baffle via the board so thermistor should read @20 c room temp 3k.
    If you need a diagram pm me.
    BG
    #297838
    subs
    Re: FF72P Baffle
    Thanks spimps, so it seems like its going to be the sensor.
    What are the 2 white wires coming from the baffle, should’nt i be getting continuaty through them?
    Subs
    #297839
    spimps
    Re: FF72P Baffle
    If the sensor fails it automatically leaves the baffle open,hence the freezing in fridge.
    Very small baffle motor can’t see any readings for it.
    Sensor is 2600284
