FFA 71P
  • #48967
    United
    Hi, got a Hotpoint FFA71P. Fridge appears to be working fine, freezer is doing nothing, evaporator all defrosted and no fan running. Freezer high temp light is showing on display. Have seen threads on thermistors, but believe these are foamed in on this model.Are these likely to be the cause, or is pcb at fault?
    #298326
    Dales-Electronic
    Re: FFA 71P
    Really a shot in the dark, you need to check if you have similar resistance reading on all the thermistors if so you may have a pcb fault.
