FFA71P Warm Freezer ?
  • #65412
    a1al
    Hi Everyone,
    Has anyone got any wiring diagrams/Info on this model of Fridge Freezer they could send me? It has been “Built in” by the owner so access to the rear of the appliance is all but impossilble.
    What to see if it has a split refrigeration system before i try to dig it out.
    Freezer has no cooling at all while fridge is working fine.
    Has anyone come accross this fault before.
    Many thanks al
    #360403
    gandh1
    Re: FFA71P Warm Freezer ?
    access to rear is doddle, as has rear wheela, no back feet. to be unobtainably built in it would have to have had a trim fascia built around it… so if normal diemensions of a mistral (im assuming this is one) is 180×60 then you shouldnt have an issue
    #360404
    johnnyj
    System leak probly they are bad for leaks, they seem to think it is usualy from the anticondensation loop, bypassing it sometimes cures but you will get a recall for condensation.
    #360405
    gandh1
    is it showing any error codes? just supplied an evap thermistor for one to a cust where freezer wasnt working, its apparently cured it, one week on…
