Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › ffs 70
- This topic has 9 replies, 3 voices, and was last updated 18 years, 9 months ago by
waters.
June 20, 2007 at 4:32 pm #28317
waters
ParticipantHotpoint fridge freezer.Can someone please explain what does ,defrost food alert switch do . this is a switch,so what does it switch,it also has a holiday switch
June 20, 2007 at 5:41 pm #217853hotpnt
ParticipantRe: ffs 70
hi, its so the customer can cancel the alarm if it is showing
June 20, 2007 at 7:03 pm #217854waters
It has a separate high temp alarm with light,this alarm i am asking about is a switch with a light on the other end of the top panel,saying defrost food alarm.
When i first put the fridge freezer on both were lit,after it got up to temp,the high temp alarm went off,but the defrost food alert was still on,until i switched it .
If this is the one you are on about sorry,i cant see why the two,where would i get an instruction book,thanksJune 20, 2007 at 7:29 pm #217855hotpnt
hi, ill try to explain, the Defrost food alert warns the user when there has been a power cut, so they can check that the food has not defrosted, it will stay lit after a power failure until it is manually cancelled,(its not a switch that can turn anything on or off, just a cancel button) the high temp light is on whenever the freezer temp is above -12,
The holiday mode changes the fridge cut-in temp to a higher setting as it assumes there will be less food in the fridge whilst you are on holiday, it has no effect on the freezer settings though
hope that helpsJune 20, 2007 at 8:04 pm #217856waters
Yes thank you very much
June 22, 2007 at 9:46 am #217857waters
Do these defrost within a 24 hour period.I have had a thermometer in freezer and it is constant -20,with no drop so when do they do a defrost
June 22, 2007 at 3:57 pm #217858waters
The Mistrels defrost after 10 to 12 hours,raising the freezer temp to around-5 should i see the same with this model
June 24, 2007 at 8:30 am #217859waters
Is a Service manual available from anywhere
June 29, 2007 at 7:26 am #217860waters
No build up of ice,but still no rise in temp showing a defrost
June 29, 2007 at 3:33 pm #217861admin
KeymasterRe: ffs 70
How can see if is defrosting? 😯
At compressor container where come water drainage tube from freezer. Take the tube out or put one extension on external pot and you will see after 24hours some water in (I do open and close freezer door from time to time in order to force him to bild up more ice on evaporator). 8)Don’t drink that… is not whisky!!! 😉
