FHP Motor
  • #20592
    flash
    Hi can enybody tell me if there is a tool avalable to get the four threded bolts out to split the fhp motor any help welcome
    Glen
    #187630
    pen0668
    Re: FHP Motor
    hi flash i had to make a tool for aeg motors it was made out of 1/4 extention cut groove in and fitted coller over end worked a treet used to replace bearins (well you had to when moters were £180 ++ if you want to see it ill send photo
    darren
    #187631
    flash
    Re: FHP Motor
    HI Darren thanks for that . I will get the hacksaw out in the morning Glen
    #187632
    Re: FHP Motor
    Use a Hotpoint 95 suspension leg. Lock two 13mm headed nuts together on the threaded end. Saw a slot in the other end – voila.
    I’ve been fitting new bearings (and other devious constructions) to AEG/FHP motors for years. 30 tonne puller is useful as well…… 😀
    pen0668
    Re: FHP Motor
    hi criss i used to aeg agent meny moons ago so had to change bearings on motors had to make tool for pulling pully off though not much demand now though??
    #187634
    Re: FHP Motor
    Still a regular “nice little earner”, Pen. 30 tonne gear puller winds the pulley and front bearing off together, no bother.
    This is Yorkshire – lots of old machines still chugging along ………
