Finlux FWM146J
  • #76653
    rocker
    been to look at this washing machine today, made and sold in ireland.
    why can I buy spares in uk please.!! john
    #399369
    Jackal
    Re: Finlux FWM146J
    Me, what are you after?
    Jackal
    #399370
    rocker
    Re: Finlux FWM146J
    Jackel,
    Not sure yet, at the moment the machine only spins for a short time, about 2 to 3 mins so clothes coming out wet, need to know where to purchase spares if I take the job on.
    you seem to know a lot about these machines, any idea of possible cause. !!
    cheers John
    #399371
    Jackal
    Re: Finlux FWM146J
    Poor loading by the Cust is usually the cause of this.
    The PCB is very sensitive to out of balance so uneven and or small loads cause the OOB sensor to flip causing the spin to shut off and try to rebalance the load then try again. Net result it attempts to spin, stops then tries again and so on.
    The PCB is also common but its usually taken out but the motor shorting.
    Jacksl
    #399372
    rocker
    Re: Finlux FWM146J
    Cheers for the advice, but you haven’t mentioned where I can buy spares. john
    #399373
    Jackal
    Re: Finlux FWM146J
    Errrr I did, I used the term ME,
    meaning I can supply spares if you want them but I need to know what you want.
    Jackal
