The fan element on this oven will only heat for 5 – 10 seconds before it is switched off by the control module. I’m presuming that it must be the module or, more likely I guess, the temperature sensor which is at fault. Visual inspection of the module shows no obvious faulty joints. Sensor measures around 1k ohms at a little above room temperature.
Does anyone have any experience with this one, or a manual?
With thanks
Graham
(Service No. is 854184215020)
