Firenzi (built in) gas hob ignition switch
Home Forums Public Support Forums Spare Parts Help Firenzi (built in) gas hob ignition switch
  • #14445
    nathanc
    I need a replacement switch (as above) as I broke the fitting when cleaning the hob. I can’t find any model information without removing the hob but it looks like Firenzi only do one model anyway!
    I would appreciate it if you are able to provide any information on this part.
    Many thanks
    Nathan
    #159499
    Re: Firenzi (built in) gas hob ignition switch
    This is a whirlpool appliance and the model number is on the base of the appliance, underneath. Ususally means removing a single oven to see it!
    Look at your paperwork to see if you can find a 12 digit number begining with 85**********, that what is needed to find the appropriate part number
    Kevin
    #159500
    nathanc
    The oven has two parts, both built into the kitchen: the Oven and the Hob.
    The oven’s service tag has two numbers:
    854184215020
    140239025640
    The product booklet I have makes no mention of the hob so I doubt the above numbers may actually help me here!
    #159501
    We appear not be communicating very well here 😀 . Whilst you have bought one cooking package, it comprises 2 quite distinct appliances, each of which will have its own code numbers.
    You are going to have to get down underneath the hob with a torch and get the numbers.
    nathanc
    You were communicating fine Penguin45 :lol:, I just wanted to avoid having to take my kitchen apart to find the model number 🙄
