Firenzi dishwasher DW930/1
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Firenzi dishwasher DW930/1
  • #51406
    becrooni
    Hi there,
    I am having a problem with my integrated Firenzi DW930/1 dishwasher. It will start as normal and then begin beeping continuously. When i open the door the right hand light flashes and the onyl way to start it is to hold it down for 5 secs and then again to turn in back on. It then conitunes for a short while and beeps repeatedly again. Am I doing anythig wrong and do you think it is worht getitng an engineer out or just getting a new dishwasher?
    I look forward to hearing from you.
    Kind Regards,
    Bec.
    #307945
    Re: Firenzi dishwasher DW930/1
    Holding down the button cancels the programme and runs the drain pump for two minutes. You can then re-set the programme and try again.
    When it faults, the start LED will flash in a pattern – ie – 1-2-3-4-pause-repeat. This is an error code, which we can interpret for you.
