Just been to a Firenzi DO 95IX cooker top oven working OK main fan oven not working because the display shows STOP but will not change when the button is pressed I have checked the switch behind the button and it works OK right back to the display board.
checked both boards for dry joints all seem OK no physical damage on either board all connectors nice and tight etc tried switching the supply on and off numerous times.
Has anyone else had this problem and pinned the fault down?
Could it be the display board or the main power board?
Cheers
Auldyn Electrics
