firenzi dw930
  • #31510
    streetlighter
    Hi all
    I have a fault with a d/w firenzi dw930 ( looks like a wpl ) its a 4 flashes code but the d/w is empty at start.
    After a reset it pumps for a while and then flashes 4 times, no fiil, didn’t check to see if drain or wash pump as it was a built in jobi.
    cant find a presure pipe under neath is this a lense type d/w as iv’e not come across one of these yet.
    It is empty and says not pumping out, or Have I got the fault code wronge.
    Has anyone come across this problem before as I am stumped.
    Paul
    #231417
    DentedPorsche
    Re: firenzi dw930
    It’s a whirlpool in disguise. Remove the mesh filter and check that the black grid (pressure switch) isn’t gunged up.
    Brian
    #231418
    streetlighter
    Re: firenzi dw930
    Thanks Brian I will try that tommorow.
    Paul
