Firenzi DW930/1 will stop during cycle, beep and flash
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Firenzi DW930/1 will stop during cycle, beep and flash
  • #17891
    dionisis
    I have found a few threads on similar problems with those, but dont quite much mine.
    My dishwasher will start the programm normally and then at some point during the cycle it will start beeping continuously and stop. After some monitoring I think that it tends to stop after draining the water. Not always at the same draining cycle, sometimes after rinsing, sometimes after the wash, etc.
    The start light flashes 4 times, stops and starts again. After resetting by it will start again but might/might not stop again later.
    Could you please direct me at what I should look for?
    Dionisis
    #176904
    Dave_Conway
    Re: Firenzi DW930/1 will stop during cycle, beep and flash
    4 flashes (or E4) is a no drain error so check for blockages where the waste hose connects to the sink trap (if it does) or kinks in the waste hose.
    There should be more on this in the forums, check the Whirlpool ones as they make this dishwasher for Firenzi.
    Power off please if you go inside :zap: or check the repairs@ link below if you need pro help 🙂
    #176905
    dionisis
    Thanks for the response Dave.
    The problem is that the dishwasher does drain the water, although the drain pump seems to go on working. I can confirm that there is no more water than normal in the machine when it beeps.
    Could it be a water drain sensor? and where would that be located?
    I have already changed the main Askol pump on this machine for another problem but after putting back together this problem has appeared.
    Thanks again for the help.
    Dionisis
